ranskalaiset keksii AINA jotain erikoista
Viesti Kirjoittaja TAp » To Toukokuu 19. 14:22:02 2011
Autocarin sivuilta:
Citroen is recalling more than 20,000 Citroen C3 Picasso’s following the discovery that the car’s brakes can be applied from the passenger footwell.
The fault stems from the manufacturing process during the C3 Picasso’s conversion from left-hand drive to right-hand drive for the UK market.
The brake cable - which is transferred to the right side of the car from the left - is covered by a thin piece of felt on the left side, which can be pressed easily by passengers, applying the brakes.
Recalled cars will be fitted with an additional brake isolator to eliminate the problem.
KtK
Re: ranskalaiset keksii AINA jotain erikoista
Viesti Kirjoittaja KtK » To Toukokuu 19. 15:43:19 2011
Hyvä systeemi yksityiseen Autokoulu tarkoitukseen ja voi helposti hillitä liian rajua kuskia. Citroen on aina ollut edellä muita.
