Focus RS mk1 FINIS koodeja
kemes
Viesti Kirjoittaja kemes » Ke Tammikuu 21. 14:02:42 2015
RS Focuksen osanunmeroita.
Code Number / Part Description
1134864 2 x RS Front Discs
1135058 RS Caliper with pads o/s
1135059 RS Caliper with pads n/s
7343535 2 x RS Hub’s
1144293 RS Knuckle n/s
1143475 x2 RS Front Spring
1135069 RS Shock o/s/f
1135104 RS Shock n/s/f
1143476 x2 RS Rear Spring
1135070 x2 RS Rear Shock
1134072 R/H RS Door Trim
1134073 L/H RS Door Trim
1134074 R/H ¼ RS Trim
1134076 L/H ¼ RS Trim
1134728 R/H RS Seat Base Cover
1134720 L/H RS Seat Base Cover
1134717 2 x RS Foam Base
1134738 R/H RS Seat Back Cover
1131423 L/H RS Seat Back Cover
1134718 2x RS Foam Base
1136176 RS Steering Wheel
1139933 RS Instrument Cluster
1237743 S/S GearKnob
1219818 Hand break lever (Complete)
1127181 Centre Dash Panel around radio/heater (Black)
1135258 Audio 6006E Security Panel
1142271 Glovebox Light
1097542 'Ghia' Intermittent Wiper Stalk
4130504 'Ghia' Internal Lamp with Map Lights
1105527 Audio Stalk
1117686 Remote Control Keyfob
1132629 Mirror Inner Cover (With switch hole) o/s
1132622 Mirror Inner Cover n/s
6913144 Electric Mirror Switch
1145484 LH/RH Door Handles Primed
1202478 Lock Bezels with no key hole primed
1203320 Lock Bezels with key hole primed
1133961 Electric Mirror o/s
1133966 Electric Mirror n/s
1078771 Mirror Cover (Primed) o/s
1078772 Mirror Cover (Primed) n/s
1218226 R/H RS Headlamp
1218242 L/H RS Headlamp
1211879 RS Front Bumper
1134222 RS Grille
1216718 R/H RS Wing
1216719 L/H RS Wing
1211829 RS Rear Spoiler
1149216 RS Quarter Panel
1149215 RS Quarter Panel
1211830 RS Side Skirt
1211831 RS Side Skirt
1134863 RS Wheel 8 x 18
1307094 RS Wheel Centre Caps
1089611 'Focus' Rear Tailgate Badge
1135344 'RS' Rear Tailgate Badge
1135343 2x'RS' Side Pillar Badge
6999357 Touch-Up Paint (Imperial Blue)
1137928 RS Clear Front Flasher Lamp
1137929 RS Clear Front Flasher Lamp
1030007 Bulb Holders for Front Flash Lamps
1148794 RS Clear Side Repeater Kit
1226549 Fog Lamp LH
1226552 Fog Lamp RH
Gaskets from Ford:
Turbo to decat gasket 1089965 -
Decat to flexi pipe 1217004 -
6107891 copper washers brake parts
1040740 x2 banjo fittings
1144187 x4 bolts M12 X 35mm
1135173 x2 Rear discs
6701988 grease cab rear hub
1135174 rear hub assembly complete
1135176 rear spindle o/s
1135177 rear spindle n/s
1213134 RS Spindle adaptor
1141940 splash sheilds rear o/s
1141939 splash sheilds rear n/s
1148903 screws for rear splash guards x8 M12 X 22mm
1146926 RS rubber insulator bracket assembly
7346525 2 x RS Hub’s
1135079 RS Knuckle o/s
1214041 RS Knuckle n/s
1143475 x 2 RS Front Spring - 50.54 exc vat each
1135069 RS Shock o/s/f - 149.57 exc vat each
1135104 RS Shock n/s/f now 1205237 - 111.26 exc vat each
1143476 x 2 RS Rear Spring now 1203608 - 38.86 exc vat each
1135070 x 2 RS Rear Shock - 149.57 exc vat each
1134728 RS Seat Base Cover R/H
1134720 RS Seat Base Cover L/H
1134738 RS Seat Back Cover R/H
1131423 RS Seat Back Cover L/H
1134718 2 x RS Foam Base
???????? Starter Button
1097542 Ghia' Intermittent Wiper Stalk (not O.E)
4130504 Ghia' Internal Lamp with Map Lights (not O.E)
1105527 Audio Stalk
1139649 Rear bumper mounting bracket l/h
1139647 Rear bumper mounting bracket r/h
1150343 Rear towing eye cover
1204400 RS Rear Bumper
1134222 RS Grille
1216718 R/H RS Wing
1216719 L/H RS Wing
1149216 RS Quarter Panel n/s
1149215 RS Quarter Panel o/s
???????? S/S Tyre Valve Caps
1135343 2 x'RS' Side Pillar Badge
6999357 Touch-Up Paint (Imperial Blue) now 1332784 - 6.28 exc vat
1230159 Cat to turbo clamp on FMC part finder comes up heat sheild
1226549 Fog Lamp LH
1226552 Fog Lamp RH
1073568 rear windscreen sunblind - 52.75 exc vat
1073570 rear side window sunblinds - 34.91 exc vat
1073377 plastic boot liner
1142450 Foot well mats
1222249 Engine Heatsheild top front of rocker cover Chrome
1135064 RS Steering Rack (exchange)
4327071 RS power steering pump
1226625 Outlet hose from turbo
1227883 Amal Valve
1227855 solonoid to hose to actuator
1227864 solonoid hose to turbo
1227886 solonoid hose to exhaust
??????? Boost hose intercooler to manifold
1136112 RS Water Pump Housing
1207516 RS Water Pump
1138298 RS Water Pump pulley
1141582 RS housing
1135481 RS thermostat housing
1018219 RS water pump bolt & washer assembly X3
1001993 RS thermostat
1149766 RS outlet water pump
1102051 Heatsheld water pump
1217353 RS inlet manifold
1149320 Leather Gear shift Boot
1214006 Gear Lever
1121854 reverse lift collar spring
1121945 reverse lift collar alloy
6820392 Rubber washer gear lever base
1214008 gear shift pivot
1121944 actuator assembly gear shift
1123612 connector assembly gear shifter
1147007 bracket for gear shift cable assembly
6509353 M10 hex nut
1205812 gear shift cable to gearbox 1 of 2 required
1126616 gear shift cable to gearbox 2 of 2 required
1068980 gear shift cable clip
1306260 Floor carpet midnight
1121948 bush gear shift housing
1121943 gear shift housing assembly upper
1214011 transmission control selector
1214009 gear shift housing assembly lower
1146296 Engine mount
1227880 Throttle elbow
1227870 Throttle elbow rubber gasket
4332280 throttle plate housing
1001599 potentiometer Focus RS
1144167 throttle gasket
1120437 accelerator bracket
1090949 inlet manifold Gasket x 4 reqd
1054013 Gasket
1223957 inlet manifold bolt spacer x2 reqd
1228059 inlet manifold heat shield
1205688 support bracket
1079827 blanking cap Focus RS only!
7165249 Gasket
1149611 bypass valve
1217355 Bracket
1137631 fuel regulator
1203089 injection fuel rail
1053951 injector retaining clip x4 reqd
1136046 standard injectors x 4 reqd
1136222 heater hose outlet
1134560 connecting hose
1205551 hose assembly
1134140 brake hose front O/S
1137802 brake hose front N/S
1204444 hose overflow
1139240 radiator hose upper
1134583 radiator hose upper
1141724 radiator hose lower
1134578 rad hose to header tank
1150362 rad hose to header tank
1135352 Air cleaner assembly
1232330 air filter
1138279 air duct to turbo intake
1227214 re-circ dump valve
3043533 air charge sensor
1227881 dumpvalve to inlet tube
1227884 dump valve to inlet manifold
1228018 blanking plate for MAF sensor
1227868 Air box mounting bracket
1136109 Turbocharger
1136111 Exhaust Valve (inlets are standard zetec e items)
1217354 exhaust manifold
1035595 O2 Sensor (blue)
1136214 cataytic convertor
1135084 cat to exhaust coupler
1053108 Hego sensor (green)
1134864 Brake discs x2
1037660 Cam belt
1216075 Camshaft pulleys
1107573 Cam belt tensioner
1213852 Cam belt idler pulley
1663875 Cam belt guide
1135052 Cam belt damper assembly
1216141 Cam belt crankshaft gear
1230634 Complete clutch kit less release bearing
7166796 Release bearing
1214775 cylinder assembly
1137993 tailgate handle painted
4184381 door moulding primed O/S
4184382 door moulding primed N/S
1204377 rear qtr moulding painted O/S
1204380 rear qtr moulding painted N/S
1136724 anti roll bar bushes
4186514 anti roll bar
1135077 tie bar
1150984 drive shaft
1216710 Cylinder head complete with valves
1105772 Cylinder head gasket
1135346 engine block
1144165 turbo ceramic heatsheild
1207156 water pump kit
1150348 front strut bump stop
1141589 exhaust manifold heatsheild
1144132 Camshaft cover (rocker cover RS)
1126120 Camshaft cover (rocker cover RS) Gasket
1053902 head to exhaust manifold gasket
1227210 Alarm fob £42.34+vat
1230737 Brake hose protector under front wings stops rubbing paint
1226543 Starter Switch
5051325 Tyre Valve
1024339 Exhaust manifold studs “x7”
1224370 Long stud “x1”
6518102 Nuts for exhaust manifold (x8)
1227588 Manifold to turbo bolts (x4)
4555047 Latch Assembly Hood
1053902 manifold to head gasket
1208444 manifold to turbo gasket
1003736 manifold to head spacers (pack of 5)
1227588 turbo bolts (hex) (pack of 4)
1227190 RH Bezel; (£25.12) fog lamp cover
1227198 LH Bezel; (£13.52) fog lamp cover
1074368 Tailgate gas struts 3/5 door changed to 1150277 apparently
1212516 water pipe under O/S/F wheel arch from oil cooler to top of rad
1214775 Clutch master cylinder/clutch release bearing
1065148 Drive shaft oil seal same each side
01000530 Wheel arch protector push clips
06998849 under tray push clips x 4
4138872 MAF sensor Focus RS
1007932 front bumper clips that hold the under tray on
1146716 Water hose that feeds turbo Part Number 1M5O 8A567-AA
1128983 Scuttle panel tape/sealant -
1202935 OE Spark Plugs -
1382861 Odour Filter
1465018 Fuel Filter
1119421 Oil Filter
1146299 Front top mounts
Escort mk4 RS Turbo 2.0 16v
