Onko kukaan koskaan ihmetellyt mikä on ''Pectel-board''
Viesti Kirjoittaja JesseT » Ma Toukokuu 23. 14:49:47 2005
Itseäni on tämä ihmetyttänyt pitkään ja vihdoinkin hyvä selvitys "Stu":lta. Ajattelin että muitakin voisi kiinnostaa:
There are some benefits to Pectel software dont forget folks.
What most dont realise, is back in the 80's Pectel reverse engineered the software that runs the engine and totally rewrote it to suit their own plans, including the fantastic Pectel serial comms output and datalogger as well as water injection drive. Like it or loathe it, the software itself is great, if not a little limited with stuff i wish to do nowadays
They then wrote a front end for it called "IEMS" so that their customers could directly access the maps and map it, and they made it very user friendly indeed, anyone with even an tiny amount of engine knowledge could understand what the maps did and adjust them. In the 80s, this was a serious breakthrough and gave them a real leap forward in the mapping stakes.
What they then did, as stage 1 of their protection plan for the new idea is design a system that would scramble the finished map, so it wouldnt run a car at all. So when you had done your map, you saved it to a binary form for the Eprom, but it saved it as a kind of jigsaw, so when you plugged the chip into the ECU, no go, it wouldnt run
Stage 2 was to design the ecu hardware that then decoded the software again into a format the ecu could understand. This is now known as the "Pectel Board"
When the Pectel software was run "Through" the Pectel hardware, it would run just fine.
Therefore ensuring, that even if some gimp came along with a Eprom copier, they couldnt benefit from al Pectels hardwork without buying a Pectel board as well, which is where the profit was, thus protecting Pectels investment and securing their future somewhat. Very clever indeed, and a system we have all pretty much adopted now throughout the industry.
Hope that helps people to understand the mysterious "Pectel Board"
Yrkesman
Viesti Kirjoittaja Yrkesman » Ma Toukokuu 23. 15:38:17 2005
Se on muutenkin ihan mielenkiintoinen topicci se josta olet tuon copy pastennut.
Viesti Kirjoittaja jjs » Ti Toukokuu 24. 0:47:25 2005
Idea tuosta selviääkin; saattaa olla kyseessä Pectelin -babyboardin- sukulainen :wink:
Peltsi
Viesti Kirjoittaja Peltsi » Ti Toukokuu 24. 1:27:09 2005
Mulla on Pectelin A ryhmän boxi
Onko kellään tietoa mitä eroa tavalliseen N ecuun?
Harmaat suuttimet ,vesiruisku muuta?
http://www.cossu.k-netti.nu/main/photos ... _id=207946
Sierra Cosworth 4x4 -91 R.N/A
Escort RS Cosworth -92
Jahman
Viesti Kirjoittaja Jahman » Ti Toukokuu 24. 1:47:47 2005
jjs kirjoitti:Idea tuosta selviääkin; saattaa olla kyseessä Pectelin -babyboardin- sukulainen :wink:
Eikös tuon "babyboardinkin" funktio ole datan dekoodaus ja kopioinnin esto/hankaloittaminen?
Edit: oma L8 poksi
Tässähän se menee...
Yrkesman
Viesti Kirjoittaja Yrkesman » Ti Toukokuu 24. 8:12:18 2005
Jahman kirjoitti:
Edit: oma L8 poksi
Näinhän se taitaa olla. Siinä on epromin lisäksi ne kaks ohjelmoitavaa logiikkapiiriä (riippuu vähän levystä), jotka dekoodaa datan.
